Lt ganz nackt
- Kranturm
Lt ganz nackt
Hi
Habe heute meine Lt ausgezogen, unteranderem um die Siri der Gabel zu erneuern
http://lh6.ggpht.com/_PTASDn7IKCw/TSjlF ... GP0969.JPG
http://lh4.ggpht.com/_PTASDn7IKCw/TSjlV ... GP0970.JPG
http://lh3.ggpht.com/_PTASDn7IKCw/TSjlk ... GP0971.JPG
http://lh5.ggpht.com/_PTASDn7IKCw/TSjl1 ... GP0972.JPG
http://lh6.ggpht.com/_PTASDn7IKCw/TSjmJ ... GP0973.JPG
http://lh4.ggpht.com/_PTASDn7IKCw/TSjmd ... GP0974.JPG
http://lh5.ggpht.com/_PTASDn7IKCw/TSjms ... GP0975.JPG
http://lh6.ggpht.com/_PTASDn7IKCw/TSjm9 ... GP0976.JPG
http://lh5.ggpht.com/_PTASDn7IKCw/TSjnQ ... GP0977.JPG
http://lh3.ggpht.com/_PTASDn7IKCw/TSjnh ... GP0978.JPG
http://lh6.ggpht.com/_PTASDn7IKCw/TSjnx ... GP0979.JPG
http://lh6.ggpht.com/_PTASDn7IKCw/TSjoA ... GP0980.JPG
http://lh6.ggpht.com/_PTASDn7IKCw/TSjoS ... GP0981.JPG
http://lh5.ggpht.com/_PTASDn7IKCw/TSjoi ... GP0982.JPG
http://lh6.ggpht.com/_PTASDn7IKCw/TSjoz ... GP0983.JPG
http://lh5.ggpht.com/_PTASDn7IKCw/TSjpE ... GP0984.JPG
http://lh4.ggpht.com/_PTASDn7IKCw/TSjpV ... GP0985.JPG
http://lh5.ggpht.com/_PTASDn7IKCw/TSjpl ... GP0986.JPG
Gruß Peter
- Kranturm
Re: Lt ganz nackt
http://lh6.ggpht.com/_PTASDn7IKCw/TSjp2 ... GP0987.JPG
http://lh3.ggpht.com/_PTASDn7IKCw/TSjqG ... GP0988.JPG
http://lh4.ggpht.com/_PTASDn7IKCw/TSjqU ... GP0989.JPG
http://lh6.ggpht.com/_PTASDn7IKCw/TSjql ... GP0990.JPG
http://lh5.ggpht.com/_PTASDn7IKCw/TSjq3 ... GP0991.JPG
http://lh3.ggpht.com/_PTASDn7IKCw/TSjrH ... GP0992.JPG
http://lh6.ggpht.com/_PTASDn7IKCw/TSjrY ... GP0993.JPG
http://lh3.ggpht.com/_PTASDn7IKCw/TSjrq ... GP0994.JPG
http://lh4.ggpht.com/_PTASDn7IKCw/TSjr6 ... GP0995.JPG
http://lh4.ggpht.com/_PTASDn7IKCw/TSjsM ... GP0996.JPG
http://lh4.ggpht.com/_PTASDn7IKCw/TSjsg ... GP0997.JPG
http://lh3.ggpht.com/_PTASDn7IKCw/TSjsx ... GP0998.JPG
http://lh5.ggpht.com/_PTASDn7IKCw/TSjtC ... GP0999.JPG
http://lh3.ggpht.com/_PTASDn7IKCw/TSjtT ... GP1000.JPG
http://lh5.ggpht.com/_PTASDn7IKCw/TSjtl ... GP1001.JPG
Gruß Peter
- FRS 3263
- Mopped(s): R 1200 R
Re: Lt ganz nackt
Wer hätte das gedacht, da steckt ja doch ein Motorrad unter dem ganzen Plastik.
- Mopped(s): Boxer
Re: Lt ganz nackt
Hi Peter,
ist ja wirklich interessant. Hätte nicht gedacht, was für ein Technik-Chaos da unter der Verkleidung steckt
An vielen Punkten ist Korrosion zu sehen: wie alt ist Deine Dicke und welche Laufleistung hat sie?
Ich drücke Dir beide Daumen, dass Du alle Einzelteile wieder richtig zusammenkriegst...
Grüße aus dem Taunus
Holger
Holger
- Andreas.M
- Mopped(s): R1250GS Adventure "Exclusive"
Re: Lt ganz nackt
TaunusRider hat geschrieben:Hi Peter,
ist ja wirklich interessant. Hätte nicht gedacht, was für ein Technik-Chaos da unter der Verkleidung steckt.
Ich drücke Dir beide Daumen, dass Du alle Einzelteile wieder richtig zusammenkriegst...![]()
Servus Holger,
das wird er schon packen der Peter, das macht er immer wenn es Ihm langweilig ist, also jedes Jahr.
ganztiefduckundganzweitweg
pfüad Gott
Andreas
Andreas
- Kranturm
Re: Lt ganz nackt
HiFRS 3263 hat geschrieben:Wer hätte das gedacht, da steckt ja doch ein Motorrad unter dem ganzen Plastik.![]()
wenn ich Lust habe wird daraus eine RS
Gruß Peter
- Kranturm
Re: Lt ganz nackt
Ist Baujahr 99 , das sind nunmal 11 Jahre und im Motorrad wird nie geputztTaunusRider hat geschrieben:Hi Peter,
Werde meine Zweite auch zerlegen und die Lackteile umbauen.
Gruß Peter
- mani48
- Mopped(s): K 1200 LT
Re: Lt ganz nackt
na da kann man mal sehn, was für ein Gamel sich da mit der Zeit ansammelt.
Am besten schnell wieder dicht machen
http://www.cosgan.de/images/smilie/vers ... e/n055.gif
Gruss Manfred
Lebenskunst besteht nicht zuletzt in der Fähigkeit, auf etwas Notwendiges zu verzichten, um sich etwas Überflüssiges zu leisten.
Gruss Manfred
- Mopped(s): Boxer
Re: Lt ganz nackt
11 Jahre - okay, da kann man nicht meckern. So manches Fremdfabrikat hätte da mehr Rostprobleme.Kranturm hat geschrieben: Ist Baujahr 99 , das sind nunmal 11 Jahre und im Motorrad wird nie geputzt![]()
Ich hätte trotzdem das Bedürfnis, mit einem Kärcher und Warmwasseranschluss und Shampoobeimischung da vorsichtig alle Dreckecken zu beseitigen
Holger
Holger
Re: Lt ganz nackt
Wasser, Shampoo, Ballistol, watt is dat dann ? Könnte sein das sie dann nicht mehr will
Was Peter?
- Raime
- Mopped(s): K1200LT,HD1340,MG Le Mans
Re: Lt ganz nackt
Hi Peter !!
Ich sag nur Respekt !! Das würd ich mir nicht zutrauen meine Dicke so zu zerlegen !!
Beneide dich darum - aber meine alte HD ShovelHead hat früher auch oft so da gelegen,
bloß ist die Technik dagegen = Steinzeit. Dafür läuft sie jetzt immer und tadellos und
pulverbeschichtet ist sie auch! Hoffe daß mich meine 99erLT auch nicht im Stich läßt !
Raime
Raime
- Kranturm
Re: Lt ganz nackt
Hi
So auf Wunsch von Boxerfriedel jetzt bilder von der Ganganzeige zum Getriebe.
Zum Testen nimmt man am besten sein Ersatzgetriebe aus dem Regal und schließt es neben der LT an
Ok ich habe eins .
http://lh5.ggpht.com/_PTASDn7IKCw/TSmih ... GP1005.JPG
Der obere Stecker ist für die Ganganzeige.Rechte Seite zu finden
http://lh4.ggpht.com/_PTASDn7IKCw/TSmix ... GP1006.JPG
Steckverbindung Rückwärtsgang
http://lh4.ggpht.com/_PTASDn7IKCw/TSmjA ... GP1007.JPG
Stecker und Kabel am Getriebe, vorne Rüchwärtsgang ,rechts hinten Ganganzeige.
Steckverbindung im Abzweigkasten unterm Tank rechts der Wieße und blaue Stecker gehen zum Tacho ich meine im blauen sind die Kontakte der Ganganzeige , müßte ich aber im Schaltplan noch mal überprüfen
Gruß Peter
- Porto
Re: Lt ganz nackt
Hallo Peter.Raime hat geschrieben:Hi Peter !!
Raime
Da schließe ich mich dem Raime an.
Sind verdammt rötlich, manche Teile/Verschraubungen.
Wechselste die dann auch gleich mit ?
zB. vom Krümmer ?
Viel Spass und nochmals, alle Achtung.
Gruß,
Porto.
Porto.
- Donald
- Skype: Donald1275
- Mopped(s): Cx 500 / K 1100LT / K1200LT
Re: Lt ganz nackt
Hallo Kranturm,
habe meine halb nackig gemacht will bei dieser Aktion auch den Luft und Benzinfilter ? wechseln , wo find ich den B.filter.
Vielen Dank für Eure mithilfe
Ronald
Ronald
Cx 500 / K 1100 LT / K1200 LT ( Wohnzimmer dabei, Mikrowelle in Vorbereitung)
- Elvis1967
Re: Lt ganz nackt
Benzinpumpe rechts unten am Tank. Die muß raus, da findest du ihn dann.
K 1200 LT & R1200GS Adventure
- Kranturm
Re: Lt ganz nackt
HiDonald hat geschrieben:Hallo Kranturm,
Ronald
Der Luftfilter ist unterm Tank und der Benzienfilter im Tank . Wobei ich persöhnlich den Benzienfilter erst tauschen würde wenn du Probleme bekommst. Leg das Geld lieber für Schnellkupplungen der Benzinleitungen an-
Gruß Peter
- Kranturm
Re: Lt ganz nackt
HiPorto hat geschrieben: Hallo Peter.
zB. vom Krümmer ?
Das hatte ich mir auch überlegt, und bin zu dem entschluß gekommen die Kettenleidschienen auch zu erneuern. So wie den Siri des Hallgebers
Schau am besten mal beim MTCG Forum rein , da will ich den auch die Komentare dazu geben und noch weitere Bilder rein setzen ansonsten wird es langsam Forumstress.
Gruß Peter
- Kranturm
Re: Lt ganz nackt
HiElvis1967 hat geschrieben:Benzinpumpe rechts unten am Tank. Die muß raus, da findest du ihn dann.
Ne Frank im Tank unter dem Großen Flansch wo die Schläusche rein gehen. Da sitzt der ganze Krempel.
Wollte schon immer mal meinen Ersatz Tank aus einander nehmen und mir die Sache ansehen; Bin aber immer Unterwegs.
Gruß Peter
- Elvis1967
Re: Lt ganz nackt
So Schaut das aus. Pumpe mit Filter, so wie ich gesagt habe.
http://www.fotos-hochladen.net/uploads/270akp46.jpg
- Gottfried
Re: Lt ganz nackt
Peter, das ist der große Flansch und die Schläuche sind auch zu sehen
- Kranturm
Re: Lt ganz nackt
HiGottfried hat geschrieben:Peter, das ist der große Flansch und die Schläuche sind auch zu sehen
Würde jetzt gerne wissen wo Frank ihn gefunden hat.
Gruß Peter
- Elvis1967
- Donald
- Skype: Donald1275
Re: Lt ganz nackt
Halo Guten Morgen liebe LT Gemeinde,
wenn man die Dicke schon zerlegt hat und am Tank Schnellkupplungen machen will, was ist besser Kunststoff oder Metallkupplung welche Erfahrungen habt Ihr damit gemacht.
Ronald
Ronald
- Elvis1967
Re: Lt ganz nackt
Nimm welche aus Metall, die können nicht zerbröseln wie die Kunststoffteile
- Andreas.M
Re: Lt ganz nackt
Servus zusammen,
also bei meiner letzten Inspektion im April 2010, wurden die Kunststoffkupplung gegen die Metallkupplung ausgetauscht.
pfüad Gott
Andreas
Andreas
