MapSource 6.9.1 Update
Christiane
#1 Beitrag von Christiane »
http://www.boxer-talk.de/forum/showtopi ... 1131587940
Schönen Dank für die Information, Manfred!
Moin zusammen,
sollte es jemand interessieren:
http://www.garmin.com/support/download_ ... jsp?id=209
Changes made from version 6.8 to 6.9.1:
Changed to merge data received from a GPS into the current document.
Added several map POI icons, including summit, landmark, arena/track, sports/fitness center, city hall, dealer/auto parts, and bowling center.
Added the ability to view the data contained in the current document in Google Earth, if it is installed.
Added support for importing LOC files.
Added the product restrictions dialog, which is shown when you open a map product that has limitations imposed by license restrictions with the map data vendor.
Improved error reporting during communication with PocketPC devices.
Changed the Route Preferences page to use a simpler road-selection preference.
Changed to not show detailed map outlines when viewing areas that are not installed (in a partial install).
Changed to notify the user what invalid data is received from a GPS, so that the user can correct or remove this data on the GPS.
Changed the SI unit for speed from “kph” to “km/h”.
Changed the splash window (shown at program startup) to be displayed on the same monitor that the program will be displayed on, in multi-monitor configurations.
Changed the product info dialog to be resizable.
Changed contour lines with no elevation data to display the string “Contour Line” instead of “Invalid Elevation”.
Fixed an issue where a user’s data selection on the map was not visible in the user data list.
Fixed an issue with a track segment selection being displayed after the track dialog was dismissed.
Fixed issue with removing the last track point in the Track dialog.
Fixed an issue with driving directions for routes that take a series of unnamed roads.
Fixed an issue with certain key-stroke combinations in the track dialog.
Fixed an issue with selecting the wrong track segment on the map when many track segments are close together.
Fixed an issue where a selected track point was obscured by the scroll bar in the track dialog.
Fixed a drawing artifact that could be caused when displaying a context menu over user data.
Fixed an issue where addresses in multi-language products where not found when city names were in certain languages.
Fixed an issue with creating a waypoint on certain map features when the map’s language is not the same as the computer’s language setting.
Fixed issue with the UTC offset not being remembered properly in the Tide Prediction Dialog.
Fixed issue with parking and rest-area labels not showing up properly in some NT maps.
Fixed an issue exporting a GPX file that contained a waypoint with custom symbol 31.
Fixed an issue with sending NT maps to Palm devices.
Fixed 'Find Places' dialog to correctly handle states that occur in multiple countries.
Fixed an issue with the waypoint symbol not being updated on the map when it was changed back to the original symbol in the waypoint dialog.
Fixed an issue with the duplicate street names being shown in popup windows.
Christiane
Gute Mädchen kommen in den Himmel, böse überall hin!
