@ all
Es gibt ein neues Update auf 6.5
guckst Du hier
http://www.garmin.com/support/download_ ... jsp?id=209
Rainer
Update Mapsource
- rdeck1
- Mopped(s): K1200LT / R1200ST
Update Mapsource
- Stefan
- Mopped(s): nach 12Jahren LT jetzt R1200RT
@all
Am 16.September ist ein neues Update erschienen!
MapSource 6.9.0 Beta! (11,34 MB)
Guckst du hier: http://www.garmin.com/support/download_ ... jsp?id=998
Change History
Changes made from version 6.8 to 6.9 Beta:
* Change to warn users when the beta will expire. This is done in the application’s title bar, at startup (this can be silenced), and in the about dialog.
* Change to merge data received from a GPS into the current document.
* Added several map POI icons, including summit, landmark, arena/track, sports/fitness center, city hall, dealer/auto parts, and bowling center.
* Added the ability to view the data contained in the current document in Google Earth, if it is installed.
* Added support for importing LOC files.
* Added the product restrictions dialog, which is shown when you open a map product that has limitations imposed by license restrictions with the map-data vendor.
* Improved error reporting during communication with PocketPC devices.
* Changed the route preferences page to use the same road class avoid/prefer design used in newer GPS’s.
* Change to not show detailed map outlines when viewing areas that are not installed (in a partial install).
* Change to notify the user what invalid data is received from a GPS, so that the user can correct or remove this data on the GPS.
* Changed the SI unit for speed from “kph” to “km/h”.
* Changed the splash window (shown at program startup) to be displayed on the same monitor that the program will be displayed on, in multi-monitor configurations.
* Changed the product info dialog to be resizable.
* Changed contour lines with no elevation data to display the string “Contour Line” instead of “Invalid Elevation”.
* Fixed an issue where a user’s data selection on the map was not visible in the user data list.
* Fixed an issue with a track segment selection being displayed after the track dialog was dismissed.
* Fixed an issue with driving directions for routes that take a series of unnamed roads.
* Fixed an issue with certain key stroke combinations in the track dialog.
* Fixed an issue with selecting the wrong track segment on the map when many track segments are close together.
* Fixed an issue where a selected track point was obscured by the scroll bar in the track dialog.
* Fixed a drawing artifact that could be caused when displaying a context menu over user data.
* Fixed an issue where addresses in multi-language products where not found when city names were in certain languages.
* Fixed an issue with creating a waypoint on certain map features when the map’s language is not the same as the computer’s language setting.
Vielleicht kann das ja mal einer unserer Englisch-Experten übersetzen?!
Gruß Stefan
Change History
Gruß Stefan
Wissen ist Macht; nix wissen macht auch nix!
Ich mochte meine beiden LT's, weil ich durch sie so viele nette Leute kennengelernt hab'.
http://www.danasoft.com/sig/Anonymisnich.jpg
- Hubbs
- Mopped(s): K 1600 GTL
Hi Rainer, hab´mir mal den Spass
gemacht und von GOOGLE übersetzen lassen :
Ändern Sie, um Benutzer zu warnen, wenn der Betawille ablaufen. Dieses wird im Titelstab der Anwendung, am Start (dieses kann silenced) und im ungefähr Dialog getan. * Ändern Sie zum Mischen die Daten, die von einem GPS in das gegenwärtige Dokument empfangen werden. * Fügte einige Ikonen des Diagramms POI, einschließlich des Gipfels, des Grenzsteins, arena/track, der sports-/fitnessmitte, des Rathauses, der dealer-/autoteile und der Bowlingspielmitte hinzu. * Addierte die Fähigkeit, die Daten anzusehen, die im gegenwärtigen Dokument in der Masse Google enthalten wurden, wenn sie angebracht wird. * Zusätzliche Unterstützung für das Importieren der LOC-Akten. * Addierte den Produktbeschränkungsdialog, der gezeigt wird, wenn Sie ein Diagrammprodukt öffnen, das die Beschränkungen hat, die durch Lizenzbeschränkungen mit dem Diagramm-Datenverkäufer auferlegt werden. * Verbesserte Störung, die während der Kommunikation mit Vorrichtungen PocketPC berichtet. * Änderte die Wegpräferenzsseite, um das gleiche Design der Straßenkategorie zu verwenden avoid/prefer, das in neueren GPS's verwendet wurde. * Die Änderung zum nicht Zeigen der ausführlichen Diagrammumreißen, wenn sie Bereiche, die nicht angebracht werden (in einem teilweisem, anbringen) ansieht. * Ändern Sie, um den Benutzer mitzuteilen, was unzulässige Daten von einem GPS empfangen werden, damit der Benutzer diese Daten bezüglich des GPS beheben oder entfernen kann. * Änderte die SI-Maßeinheit für Geschwindigkeit "vom kph" zu "km/h". * Änderte das auf dem gleichen Monitor, daß das Programm an angezeigt wird, in den Multimonitorkonfigurationen anzuzeigende Spritzenfenster (gezeigt am Programmstart). * Änderte den Produktinfo-Dialog, um resizable zu sein. * Geänderte Form zeichnet ohne Aufzugdaten, um die Zeichenkette "Formlinie" anstelle "vom unzulässigen Aufzug" anzuzeigen. * Reparierte eine Ausgabe, in der Datenvorwähler eines Benutzers auf dem Diagramm nicht in der Benutzerdatenliste sichtbar war. * Reparierte eine Ausgabe mit einer Schienensegmentvorwähler, die angezeigt wurde, nachdem der Schienendialog entlassen wurde. * Reparierte eine Ausgabe mit Antriebsdrehrichtungen für Wege, die eine Reihe namenlose Straßen nehmen. * Reparierte eine Ausgabe mit bestimmten Schlüsselanschlagkombinationen im Schienendialog. * Reparierte eine Ausgabe mit dem Vorwählen des falschen Schienensegments auf dem Diagramm, wenn viele Schienensegmente nah zusammen sind. * Reparierte eine Ausgabe, in der ein vorgewählter Schienenpunkt durch den Rollestab im Schienendialog undeutlich gemacht wurde. * Regelte ein zeichnendes Kunstprodukt, das verursacht werden könnte, als, ein Kontextmenü über Benutzerdaten anzeigend. * Eine Ausgabe in der Adressen in den Multisprachprodukten reparierte, wo nicht gefunden, als Stadtnamen in bestimmten Sprachen waren. * Reparierte eine Ausgabe mit dem Verursachen einer Zwischenstation auf bestimmten Diagrammeigenschaften, wenn die Sprache des Diagramms nicht dieselbe wie die Computerspracheeinstellung ist.
wer´s versteht
,da bin ich froh das ich kein Navi habe
und mich auf´s wesentliche konzentrieren kann.
moppedfahren
gruss Markus
wer´s versteht
gruss Markus
K 1600 GTL, für das grinsen im Manne http://images.spritmonitor.de/564554.png
