im Netz nach einer älteren Version suchen und installieren oder ignorieren.
neue Basecamp Version verfügbar ....
- Lumi
Re: neue Basecamp Version verfügbar ....
und jetzt
GS 2015
- Lumi
- Lumi
zur Ergänzung noch das Änderungslog:
diesen Download-Link
Installation über Basecamp -> Hilfe oder manuell überGarmin hat geschrieben:Changes made from version 4.4.2 to 4.4.4:
- Fixed several issues when using the Pan Tool and the <ALT> key to move route points
Fixed autorouting issue where straight line segments were inserted after each waypoint
Improved track to route behavior. Now supports preserving the shape of track sections that aren't near a road.
Improved handling in situations where the computer is low on memory
Changed displayed route times to take layovers into account
Fixed issue with 'higher education' map symbols showing up as airports
Fixed certain instances of route direction text where the text was 'turn left/right' instead of 'bear left/right'
Fixed issue when recalculating a route via the context menu in the data list
Fixed various issues sending data to memory cards
Changed to automatically unlock BirdsEye for a device when sending the BirdsEye to a card in that device
Fixed various issues with Adventure search
Fixed issue sending ADM files to cards for marine devices
Added the command line option /Disable3D to disable the 3D view in BaseCamp. This was added to prevent startup issues with misbehaving graphics drivers.
- Lumi
Muß mal gucken ob das Darstellungsproblem noch besteht.
GS 2015
- Pendeline
- Mopped(s): R1250GS, R9T
Nach Neuberechnung einer alten Route mit Darstellungsfehler mit BC 4.4.4. war der Fehler behoben.
Gruß - Pendeline
Gruß - Pendeline
- Lumi
Changes made from version 4.4.4 to 4.4.6:
- Fixed issue with BaseCamp copying BirdsEye from a SD card each time the card is connected
Fixed issue with dragging a find result into the route point list
Fixed issue with the Find POI category and subcategory drop downs not properly updating the search
Fixed another issue when using the Hand tool and ALT key to insert route points while Trip Planner is open
Fixed issue with the displayed route total times
Fixed issue with not properly detecting waypoint merge conflicts when receiving data from the device.
Added back the "Create BirdsEye from selection" menu item, when the selection contains BirdsEye
Fixed odd selection behaviour when using the Hand tool to pan the map
Fixed issue with inserting route or track points with the hand tool not always choosing the correct insert location
Fixed various other issues
- Lumi
Änderungen von V4-4-6 zu 4-4-7
Fixed not being able to insert track points at the end of a track
Fixed GPI files not being read from SD cards
Fixed not receiving FIT locations from the fenix 3
Fixed Trip Planner printout not showing correct times
Fixed error calculating statistics when multiple tracks are selected
- Lumi
Änderungen von 4.4.7 nach 4.5.0:
Garmin hat geschrieben:Added user preference to configure mouse hover tool tips
Added selection of map product and search to the Create Route dialog
Added menu item to launch the Create Route dialog
Added hotkey (Ctrl) to draw direct route segments while routing
Added postal code searches for supported map products
Added ability to add and edit certain data directly on PND devices (data that has not yet been read by the device)
Added ability to manage waypoints on the fenix 3, including delete (requires firmware version 4.21 or greater).
Added icons for VIRB action camera and wearable devices
Made it easier to see and access BirdsEye help
Improved first time speed of quick search and address search
Improved street matching in address search
Improved handling for Google Earth's discontinued support
Updated Garmin Express instructions
Fixed routes sent to nuvis and zumos not displaying Junction View
Fixed reading track time from VIRB X action cameras
Fixed issue where route information was not showing in map tool tips
Fixed issue where memory cards would not display for some devices
Fixed issues with Garmin Custom Maps
Fixed issues exporting KML files
Fixed crash exporting trips
Fixed crashes opening trips
Fixed crash when disconnecting Base Station devices
Fixed crash after opening GPX files with far future timestamps
Improved error handling with some devices
Fixed various bugs
Added support for new TDB flags from cartography (no files are in the field yet)
Includes brute force street name searching
Update auf Version 4.5.1.1 ist verfügbar
BaseCamp aufrufen -> Update wird entweder automatisch angeboten oder über Hilfe -> Update jetzt installieren
Garmin hat geschrieben:Fixed problem scrolling in trip planner
Fixed problems reading some 3rd party maps
Fixed problem with search in the route dialog
Fixed not being able to export to text files
Fixed issue writing Garmin Custom Maps files
- Lumi
Jetzt
4.5.2.1
(aber bei kackt der sofort ab, somit keine Aktualisierung möglich)
4.5.2.1
GS 2015
Update über die Basecamp-Hilfe ist nicht möglich (File Corruption);GARMIN hat geschrieben:Changes to BaseCamp 4.5.2.1
- Fixed some issues sending data to devices
- Fixed issue with cancelling a route calculation while editing data on the device
- Fixed issue with FIT activities not being read from the etrex Touch
- Fixed route vias showing up in the locations list of the fenix 3 and epix
- Fixed various issues when disconnecting the device while editing data on the device
daher das UpdateFile direkt von Garmin downloaden und installieren.
- BeeMWe
- Mopped(s): R1100 RT, R1200 RT LC
Hallo und Danke,
hat über deinen Garminlink einwandfrei geklappt.
es grüßt
Gerald bzw. SieGer
kommt aber von Siebert, Gerald, weil mich Mama und Papa damals eben genau so nannten.
Gerald bzw. SieGer
- Lumi
- Päda
- Mopped(s): Aprilia Tuono V4 1100RR
Danke Anke
ähm Frank
VG
Kreidler Florett RS 50->Suzuki GS750->Suzuki GS1000->Honda X11->Yamaha FJR1300 RP13->BMW K1300S->ApriliaTuono V4 APRC 1000->ApriliaTuono V4 1100RR
- BeeMWe
hat schon jemand gemerkt was sich verändert oder ver(schlimm)bessert hat ?
Habe noch nix festgestellt.
es grüßt
Gerald bzw. SieGer
Gerald bzw. SieGer
neue Version von GARMIN BASECAMP (V4-6-1) ist verfügbar.
Änderungen von Version 4.5.2 zur 4.6.1:
- * Added support for downloading preview imagery for BirdsEye Select.
* Added support for displaying DEM shading for some cycling map products.
* Added support for track metadata from FIT files.
* Improved entry of position coordinates on the Waypoint Properties dialog.
* Improved performance of some track editing operations on the map.
* Updated the Czech translation for 'road'.
* Updated route avoidance settings to be more like PNDs.
* Fixed BaseCamp incorrectly showing certain maps on card or device as locked.
* Fixed route via departure dates not always showing as expected on the Route Properties dialog.
* Fixed routes created in BaseCamp not displaying lane assist and junction views on some nuvi devices.
* Fixed geocaches not correctly showing as found on Oregon devices.
* Fixed search issue in some maps.
* Fixed issue canceling route calculations.
* Fixed out of memory crashes related to the undo buffer growing too large.
* Fixed incorrect total space shown in the Device Information dialog for some nuvi and zumo devices.
* Fixed Send To Device and Receive From Device dialogs sometimes not allowing the user to select a device.
* Fixed an issue with BaseCamp prompting that old software updates are available.
* Fixed other various bugs.
- BeeMWe
Hallo Frank,
ich denke du wolltest den Beitrag hier einstellen.
http://www.bmw-bike-forum.info/viewtopi ... 47&t=58631
es grüßt
Gerald bzw. SieGer
Gerald bzw. SieGer
Nee nee, Basecamp ist hier, Express da drüben
von unterwegs gesendet ....
- DieterQ
- Mopped(s): K1300S
Wäre besser gewesen, ich hätte dieses Update nicht installiert. Typisch Garmin, ich hätte es wissen können.Frank@KS hat geschrieben:neue Version von GARMIN BASECAMP (V4-6-1) ist verfügbar
Gruß Dieter
