GPS-Routen auf eigenes PNA-Format konvertieren
Falls eine GPS-Route im Internet angeboten wird, die nicht in dem Format eueres Gerätes vorliegt,
kann man mit dem Tool ITN-CONVERT die Route umwandeln.
ITNConv can open the following formats:
- Autoroute Express (.axe, .axg) - Express Highway (. Axis. Axg)
- Streets & Trips (.est) - Streets & Trips (. Est)
- MapPoint (.ptm) - MapPoint (. Ptm)
- MapSource (.gdb, .mps) - MapSource (. Gdb. Mps)
- TomTom 3, 5, 6, 7 & 8 , Go, Rider, One (.itn, .ov2) - TomTom 3, 5, 6, 7 & 8, Go, Rider, One (. Itn. OV2)
- Navigon MN|4, MN|5, MN|6 & MN|7 (.rte, .route) - Navigon MN | 4, MN | 5, MN | MN & 6 | 7 (. Rte. Road)
- Becker Traffic Assist (.rte) - Becker Traffic Assist (. Rte)
- Destinator PN (.dat) - Destinator PN (. Dat)
- Marco Polo, Falk Navigator, Motorrad Tourenplaner & OnRoute (.bcr) - Marco Polo, Falk Navigator, Motorrad Tourenplaner & OnRoute (. Bcr)
- GPS eXchange (.gpx) - GPS eXchange (. Gpx)
- GPX MapSource (.gpx) - GPX MapSource (. Gpx)
- Garmin Nüvi (.gpx) - Garmin Nüvi (. Gpx)
- Garmin PCX5 (CartoExploreur) (.rte) - Garmin PCX5 (CartoExploreur) (. Rte)
- Magellan SD (Meridian et eXplorist) (.rte, .upt) - Magellan SD (Meridian and eXplorist) (. Rte. Upt)
- ViaMichelin (.xvm) - ViaMichelin (. Xvm)
- IGN Rando (.rdn) - IGN Rando (. Rdn)
- OziExplorer (.rte) - OziExplorer (. Rte)
- OziExplorer CE (.rt2) - OziExplorer CE (. TPN2)
- Google Earth (.kml) - Google Earth (. Kml)
- CoPilot 6 (.trp) - CoPilot 6 (. Trp)
- CSV ( Longitude , Latitude , Commentaires ) - CSV (Longitude, Latitude, Comments)
ITNConv to export to the following formats:
- Autoroute Express (.axe) (Version 2004 et supérieure) - Express Highway (. Axis) (version 2004 and higher)
- TomTom 3, 5, 6, 7 & 8 , Go, Rider, One (.itn) - TomTom 3, 5, 6, 7 & 8, Go, Rider, One (. Itn)
- Magellan SD (Meridian et eXplorist) (.rte) - Magellan SD (Meridian and eXplorist) (. Rte)
- XML Location (.loc) - XML Location (. Loc)
Hier der Link zum Download des Programms: ITN-CONVERT
(ist ne französische Seite, aber man kann rechts oben auf die englische Fahne klicken)
Onedesign
Re: GPS-Routen auf eigenes PNA-Format konvertieren
Die Internetseite kriegt man auch auf Deutsch, wenn man die Adresse ohne http in GoogleSuche eingibt und dann mit translate öffnet.
- rtcruiser
- Mopped(s): R 1150 RT
die aktuelle Version ist 1.73 und wie gesagt auch auf deutschOnedesign hat geschrieben:Die Internetseite kriegt man auch auf Deutsch, wenn man die Adresse ohne http in GoogleSuche eingibt und dann mit translate öffnet.
- Handi (inaktiv)
- Mopped(s): S-RR 2012
Die Info hätte ich am letzten WE gebrauchtFrank@KS hat geschrieben:ITNConv can open the following formats:
Manfred
na hättste mal die Suche bemüht .......
steht hier seit 27 Januar 200> 9 <
- Brummer Willi
- Mopped(s): R1150RT
Sorry, aber ich habe NULL Ahnung von soetwas.
Das Programm habe ich auf meinen PC geladen. o.K.
Im unteren Bereich der Seite kann ich auch die Umwandlung nach medion wählen o.K
Jetzt plane ich eine Route mit dem Motorrad-Routenplaner o.K.
Das Medion Navi ist über AktiveSync mit dem PC verbunden o.K.
UND WAS NUN ????????
Wie bekomme ich die Route umgewandelt bzw. auf das Medion Navi ?????
Ich gehe auf Export, aber wohin ???
Grüße aus dem Bergischen Land
-- Fahren und fahren lassen --
Hi Willy,
da war doch mal .... da hatte ich doch ..... ne Anleitung ....
viewtopic.php?p=336662#p336662
- Brummer Willi
Hallo Frank,Frank@KS hat geschrieben:Hi Willy,
besten Dank, eine super Beschreibung, die versteh sogar ich.
Jetzt werde ich mal testen.
Nordmann
Wenn du diese Anletung verstehst, dann geht das noch viel einfacher. Du kopierst deine konvertierte Datei xyz.xml einfach in den folgenden Pfad und fertig ist die Laube.Brummer Willi hat geschrieben: Hallo Frank,
besten Dank, eine super Beschreibung, die versteh sogar ich.![]()
\My Flash Disk\settings\0\Navigation\tour
- Brummer Willi
Besten Dank, ich werde es ausprobieren.Nordmann hat geschrieben:
- Brummer Willi
Ich bekomme eine Krise.
Hat alles wunderbar geklappt.
Die Route ist auf dem Navi und erscheint auch unter Routen.
Beim Anklicken der Route: Route kann nicht geladen werden.
Ich weiß nicht weiter.
Sorry Willi, da ich keinen Medion zur Verfügung hab', weiß ich hier auch nicht weiter
- Robi
- Mopped(s): R1250GS/LC
Salü Frank
Vielen Dank für die Info. Für die BCR File zu GPX habe ich ein Programm gefunden.
Aber für die tfe zu GPX scheint es etwas schwieriger...da ist auch auf diesem Programm nichts dabei.
gruss
Robi
gruss
Robi
Onedesign
Die meisten Umwandlungenmöglichkeiten hat noch immer der RouteConverter. Einfach mal damit probieren.
- Mark (CE)
- Mopped(s): K1200RS, K1300S, R1200GS LC
Mensch Junge, hab ja schon ewig nichts mehr von Dir gelesen. Wieder online?Onedesign hat geschrieben:Die meisten Umwandlungenmöglichkeiten hat noch immer der RouteConverter. Einfach mal damit probieren.
Gruß Mark
- Michael (GF)
Pruuuuuuuuuuuuust.............Markt, Du antwortest auf einen Beitrag aus 2010...........
- Mark (CE)
oh Mann, wie peinlich.....Michael (GF) hat geschrieben:Pruuuuuuuuuuuuust.............Markt, Du antwortest auf einen Beitrag aus 2010...........
Gruß Mark
Feuerfreund
Hi Frank,
habe eben die Abhandlung über ITN-CONVERT gelesen.
Bin Besitzer eines BMW Navi IV und wollte vom Kurvenkönig Routen laden. Liegen im .gpx Format vor. Ich habe die Dateien auf die SD-K kopiert, aber das Teil findet keine Routen. Habe es mit mehreren probiert, sodass ein Defekt der Dateien unwahrscheinlich ist.
Frage: Gibt es einen Unterschied zw. .gpx und .Gpx? Ist in Deiner Liste aufgeführt.
Hast Du eine Idee, woran es liegen kann?
Danke
Danke
Routen auf der SD müssen importiert werden.
Hast Du das schon versucht ??
